03-20-2015 12:22 PM - edited 03-05-2019 01:04 AM
I presently using a Cisco3845 router to terminate a WAN connection. The router is coming end of support starting Oct. 2016 and I need to start looking into a replacement router. I was looking into the Cisco3945, but I can't find anywhere that the NM TokenRing card (NM-1FE1R2W) is support on that model. I have time to replace the Cisco3845 routers, but I need to start looking into options.
Does anyone know if the NM-1FE1R2W is supported on the Cisco3945 router? If not, what other routers will support TokenRing that are not going end-of-support/end-of-life in the next year or so?
Gabi
05-24-2016 04:13 AM
Did you get an answer to this? I have the exact same issue..
05-24-2016 02:58 PM
05-25-2016 01:29 AM
That's the Network Module in use today (well the NM-1FE1R2W) but I can't see that as an option to purchase along with the 3945 (cisco's suggested replacement router).
Hence wondering how I can keep Token Ring capability in a current Cisco platform, and why I responded to curielg73 post as he seems to have been in this position before me..
05-25-2016 11:36 AM
You might find this discussion to be helpful
https://supportforums.cisco.com/discussion/11361971/token-ring-support-isr-g2
Rick
06-01-2016 02:26 AM
Thanks Richard, I also got it confirmed from our Cisco Engineer... Token Ring is no more..
