CISCO881W-GN-E-K9 vs. C881W-GN-E-K9
isystems.at
Does anybody know what's the difference between these routers?
For example, the CISCO881G-K9 has a 3.5G ExpressCard Modem and the C881G has an embedded one with GPS and 3.7G in most versions. The C881G is, for all I know, the newer one.
But for the two mentioned above, I can't find any differences at all. The C881 is listed in the Teleworking section of the data sheet. But there is no information whatsoever about any feature or license differences.
Google also wasn't very helpful.
Thanks in advance.
EDIT: Datasheet Link:
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps380/data_sheet_c78_459542_ps380_Products_Data_Sheet.html
The following answer is INCORRECT, for the right one scroll down:
Reza Sharifi
They are both the same. It is just one located under Ethernet section and the other one under SRST
C881W-GN-E-K9
Cisco 881 Ethernet Security Router with 802.11n ETSI Compliant
7 Replies 7
Reza Sharifi
C881W-GN-E-K9
Leo Laohoo
As Reza pointed out, they're both the same.  Can I/we ask what you are trying to achieve?
isystems.at
THX for the answers
I'm going to use the the 881 as a hardware VPN client. The endpoint is an ASA 5505.
I wan't to secure the access to the VPN on the router with 802.1x
Initially I wanted to use an ASA as client, but the ASA doesn't support 802.1x on the build in switch and the 880 routers support 802.1x for all I know and if I understood this page right.
I know the ASA has a feature called "Individual User Authentication" but, 802.1x with doesn't require any user interaction, which is a concern in this installation.
Found the information their is a difference!
http://www.cisco.com/en/US/prod/collateral/routers/ps380/qa_c67_458826.html
The C881W is fanless and has 512MB RAM.
The CISCO881W has one fan and has 256MB RAM.
For details look at the Link above.
Thanks for providing this info (+5)
It would be so much easier to put this table in the data sheet instead of putting it in another document and calling it Q&A
Here is a good document that describes the naming conventions for 800 series routers; this also helps answer the above question.
http://www.cisco.com/en/US/prod/collateral/routers/ps10906/ps380/qa_c67-716652.html
Bart Smit
The thread is already a bit old, but as time flies Cisco has put together this EOL statement:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/end_of_life_notice_c51-709985.pdf
However not mentioned there is the C881W-GN-E-K9, but according to the page with the naming conventions (thanks Vishwas) the letters -GN- are not important so I suppose that is why Cisco dropped them.
