classification: exclude ftp from a certain class
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-20-2009 03:42 AM - edited 03-04-2019 04:01 AM
I'd like to exclude ftp to be classified in a certain class af31. Would this work:
class-map match-all af31
match not protocol ftp
match access-group name af31
(The named access-list af31 contains further statements to include certain source and destinations)
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-20-2009 05:46 AM
Hello Alain,
define ACL af31 so that it denies FTP traffic
put the deny statements at the beginning and then go on with the permit statements
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-20-2009 07:53 AM
This won't work with ftp in passive mode - because the ports are dynamically assigned. Hence the need of nbar. Note that the question is also if match not protocol ftp is syntactically correct.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-20-2009 08:00 AM
Yes it would work,
The (match not) protocol is inspected by NBAR, so in this class any FTP traffic is excluded.
Mohamed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-20-2009 10:03 AM
Hello Mohamed,
good note I rated it as deserved
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_m1.html#wp1013500
there is an example very close to this case
In the following traffic class, all protocols except IP are considered successful match criteria:
Router(config)# class-map noip
Router(config-cmap)# match not protocol ip
Router(config-cmap)# exit
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-23-2009 01:50 AM
thanks - good hint... I'd like nevertheless to have the confirmation if possible that it has been indeed configured and tried, if not with with ftp, with a similar protocol, the kind of protocol with dynamic port assignment (passive mode)- difficult to put in an acces-list- otherwise I'd put it in the a simple access-list as was suggested before. You don't have a router at hand ;-) ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-23-2009 03:55 AM
Hello Alain,
when using match not protocol I think NBAR is invoked exactly like in match protocol so NBAR is capable of classify traffic with dynamic ports.
Hope to help
Giuseppe
