07-30-2019 05:46 AM
I have a problem because don´t clear counters interface port-channel in Cisco ISR4451
Router1#clear counter port-channel 1
Clear "show interface" counters on this interface [confirm]
Clear counters port-channel Cisco ISR4451
Router1#sh int port-channel 1
Port-channel1 is up, line protocol is up
Hardware is GEChannel, address is 7069.5a58.6780 (bia 7069.5a58.6780)
Description: CONEXION_A_SW1
MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
No. of active members in this channel: 2
Member 0 : GigabitEthernet0/0/0 , Full-duplex, 1000Mb/s
Member 1 : GigabitEthernet0/0/1 , Full-duplex, 1000Mb/s
No. of PF_JUMBO supported members in this channel : 2
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 00:00:06
Input queue: 0/750/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/80 (size/max)
30 second input rate 9718000 bits/sec, 10773 packets/sec
30 second output rate 10095000 bits/sec, 10806 packets/sec
55367 packets input, 6481337 bytes, 0 no buffer
Received 18446744073669073089 broadcasts (0 IP multicasts)
0 runts, 4291658617 giants, 0 throttles
4291658617 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 8574245 multicast, 0 pause input
55204 packets output, 6557287 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
07-30-2019 06:53 AM
07-30-2019 11:00 PM
The image is:
Uptime for this control processor is 24 weeks, 1 day, 4 hours, 38 minutes
System returned to ROM by PowerOn at 19:29:42 MET Thu Nov 22 2018
System restarted at 02:19:23 MET Tue Feb 12 2019
System image file is "bootflash:isr4400-universalk9.16.05.01b.SPA.bin"
Last reload reason: PowerOn
07-31-2019 12:47 AM
