Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
if a process takes more memory over time without releasing it correctly this is memory leakage and can be the effect of a software bug that could be solved with an IOS upgrade (or downgrade)
Hope to help
Giuseppe
Learn, share, save
