Clock keeps resetting
corey.mckinney
I set the Date and Time on my router and then as soon as I reload, or power off and on, it comes back saying 16:00 PST Feb 28 1993. Any suggestions?
Richard Burts
Corey
Depending on the model of router this is the expected behavior. Some of the routers (generally higher end) do have a clock chip that maintains correct time through a reload. Some of the routers (generally lower end) do not have a clock chip and do not maintain time through a reload.
Probably the best suggestion is to configure your router to run NTP and to learn time from some other device.
Rick
Rick
The specific router I'm working on right now is a 2621. It has been replaced with a 2811, and as I was configuring it as a backup, I noticed the clock resetting.
