clock timezone
Good morning,
I'm in trouble referete the time zone in roteadres cisco 3945.
I have the following settings, however the router displays the incorrect time.
clock timezone GMT-3 -3 0
summer-time clock BRV recurring Sun Oct 3 0:00 3 Sun Feb 00:00
ntp server 192.168.160.5
The other Cisco routers that have in my company use the same settings and show the correct time. Only the 3945 models have three hours more than it should.
These routers are using version: Version 15.5 (3) M2
Thank you
If you want to see the local time, you need to configure the following command:
service timestamps log datetime localtime
Good afternoon Karsten,
It is set the following services:
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service password-encryption
service sequence numbers,
However 3h shows above the local time.
You know what can be?
Entretanto mostra 3h acima do horario local.
Sabe o que pode ser?
