CMTS-cable modem termination system
CSCO10320953
Hi All,
Is CMTS7225(UBR7200-NPE-G1) require any license for activating CMTS feature and line cards(U7225VXR-M28EUG1)?
Because I am not able to configure ip address for cable interface .
CMTS(config-if)#ip ?
Interface IP configuration subcommands:
  dhcp                Configure DHCP parameters for this interface
  header-compression  IPHC options
  rsvp                RSVP Interface Commands
  rtp                 RTP parameters
  subscriber          IP session configuration options
  vrf                 VPN Routing/Forwarding parameters on the interface
Regarding,
Kumaran M
Kumaran,
This is an open community based on best-effort help.
If you need a reply in a timely manner, please open a TAC case.
As far as I know, only the new 20x20 and 8x8 cards need a specific license, you are using a 28.
A bundle interface can be used even for a single cable interface. You should use the bundle for any L3 features, and configure L2 features under the cable interface.
mavespig
Level 3
Level 3
Hi Kumaran,
Did you try to associate the cable interface to a bundle, and configure the IP in the bundle?
For example:
int cable1/0
  cable bundle 1
int bundle 1
  ip address x.x.x.x
To verify your license details, you may use the command "show license detail"
Hope this helps
Marco
Marconi,
When  we do two or more physical interface configration  ,bundle is required.
But i am using single cable inteface ,Still i have to use bundle concept.
Pl confirm,if yes,
I can able to configure ip addres in bundle interfce
interface Bundle1
ip address x.x.x.x x.x.x.x
cable arp filter request-send 3 2
cable arp filter reply-accept 3 2
cable helper-address x.x.x.x
1.Pl confirm whether license is required for CMTS
2.show license detail ,Command is not working.
WT-CMTS-BLR#sh l ?
l2tp       l2tun     line     llc2   lnm
local-ack  location  logging  login
FYI.
Marco,
I am waiting for your valuable input on my query.
Kumaran,
