cmts init(io)
b.withrow
Is anyone familiar with the cable modem state of "init(io)", as reported by a Cisco CMTS?
stephtchoko
Level 3
Level 3
I don't know init(io), but i know init (o) which means that cable modem request a config file to CMTS.
Which kind of cmts do you have ?
please, rate this post.
10012 UBR
If you cable stay in init(O), you have to verify your config-file.Make sure that after init(d) state (dhcp for getting ip address), the cable modem can communicate with CMTS.
If it is not goog, send me the config file , the dhcp pool of the cable modem and interface cable configuration.
Regards.
vivejain
Hi Brian,
Try the link below. It explains all the stages that a modem go though during startup process:
http://www.cisco.com/en/US/partner/tech/tk86/tk89/technologies_tech_note09186a0080094eb1.shtml
Let me know if this helps.
Cheers
Vivek
