Co-Location Rack Network
rayamitchell
I  am considering running stacked  3750 L3 switches as  the edge of the  network, which will connect to the  ISP. The ISP would  hand off two  lines with one to each switch and two  lines to each client  zone. Does running HSRP, running  port channels,  or running routing protocols seem like the  best option  for redundancy?
Lastly,   will the 3750 provide all the QoS I should  need for restricting each   client zone's bandwidth both up and down?  Could I get away with a  lower  model and still get these features?
Thanks for all input!!
InayathUlla Sharieff
Duplicate post.
Please see the response for this on :
https://supportforums.cisco.com/message/3893641#3893641
Inayath.
