Command in cisco 8500
jpzarate
I would like to know if some command exists in a cisco 8540, for to see the power of transmission of the interfaces ATM OC-3.
Also, I wanted to know the command or commands, to check that the redundancy of links ATM works correctly.
Thank you
Thanks.
But I wanted to know if there is some command in way console, to see the power of real transmission from a cisco 8500, in realtime.
Thanks again
