Commands
Please give me a short note about tracert and traceroute command
balaji.bandi
Both do the same task in a different environment :
tracert  - this command used most MS windows environment
traceroute command - used in cisco devices and Linux environments.
good example :
https://networklessons.com/cisco/ccna-routing-switching-icnd1-100-105/traceroute
BB
the main difference between 'tracert' (Windows) and 'traceroute' (Cisco) is that the Windows flavor uses simple ICMP echo requests, while the Cisco traceroute uses UDP packets with a random destination port.
Below a link to a pretty good explanation of the differences:
https://ccie-or-null.net/2011/08/30/the-different-between-tracert-and-traceroute/
