Committed Information Rate
dyep110581
I just wanna ask how to see the CIR on the router or what command should be issued on it? Is the CIR only For Frame Relay?
Thank you
Hi, the thing is that the SP can send any value he wants in that field, so you really have to ask them, or find by yourself.
paolo bevilacqua
Sorry, you cannot see the real CIR, but some SP send an indicative value in LMI.
Yes, CIR is specific to FR.
Thanks for that Info, One of my guy told me that if I issue "show frame-relay map" I will see a bandwidth there and could be considered as the CIR, I just like to check if thats correct or that Bandwidth is referering to other information already?
P:
If you cant trust what the SP is sending you in the LMI packets, how can you prove on your own what te CIR is?
