Communicating different VLAN using MSTP.
esh778001
Hi all,
I'm a beginner engineer, so I have a little knowledge.
I tried to configure by myself, but some problem was bothering me..
I want you guys to help me!!
Actually I configured MSTP using the 4 switches(CISCO&DELL).
Please show the attachment pictured and configuring file(.txt) ( I draw it and scanned..)
As you can see the picture, you'll know what I want to configure.
The point I want is following contents.
1. I want to communicate with whole switches.
=> but, Dell 7024P does not communicate any other switches.. I think assigning IP is vlan 30(192,168.10.91) ... others have
vlan 10(192.168.10.x)
Actually, It was very big issue.
2. Only Dell 7024P does not communicate with Internet.
So, I configured whole switches static routing (ip route 0.0.0.0 0.0.0.0 192.168.10.94)
But only 7024P does not communicate..
In order to connect each other, what can I do in the Dell 7024P switch.
Thank you.
The Dell 7024P has to be on  Vlan 10 to communicate with all the switches, and make sure you have Vlan 10 in all your trunk connections.
