Community issue
044102947
Hi all
I have 2 links to differnet ISP's, we have implemented a blackhole routing.I can advertise routes tagged with communities specified by my upsteam providers, but the problem is when i advertise a route with community speicifed by ISP-1 it is advertised to ISP-2 too.What is yor suggestions how can i prevent advertisment of routes tagged by community assigned by isp-1 to appear on ISP-2.
Thx.
Harold Ritter
You are probably configuring the route-map on the network statement, right? You should apply the route-map outbound on the specific ISP as follow:
router bgp xxx
neighbor ISP1 route-map ISP1 out
Hope this helps,
pkhatri
Level 11
Level 11
At what point are you attaching communties to your routes ? Is it when you redistribute the routes into BGP ? It might be better to use an outbound route-map on each of your BGP sessions and then apply the community there.
Hope that helps - pls rate the post if it does.
Paresh
The way I am doing this is :
route-map DDOS permit 10
set community 60:10
router bgp xxx
network xx.xx.xx.xx mask 255.255.255.255 route-map DDOS
you should add a match ip address statement in the route-map for the specific prefix and apply it outbound using the neighbot statement.
router bgp xxx
neighbor ISP1 route-map DDOS out
neighbor ISP1 send-community
match ip address 1
set community 60:10
access-list 1 permit xx.xx.xx.xx
Hope this helps,
Harold Ritter
router bgp xxx
Hope this helps,
