11-08-2011 03:20 AM - edited 03-04-2019 02:11 PM
hi all,
I'm curious if its possible to run either:
a) ppp between CE on one end to a CE over the other end over mpls
b) ppp compress over MPLS
Kind Regards,
Mina Moussa
11-14-2011 02:59 PM
No to both.
PPP is 4 bytes, there isn't really much to compress and save.
11-14-2011 03:03 PM
Thank you for the reply, however I should explain myself differently, I am trying to compress the payload which has been PPP encapsulated.
interface dialer 1
compress stac
but do this on a CE that is on the customer edge:
CE(running compression)----->PE-----P----P-----PE------>CE(running compression)
<----------MPLS------------->
