Config Mode Locked. 'Please try later.'
adamsj
Help!
When trying to input commands into the switch I get this error when I enter into the conf t.
_____________________________________________________________________________
Jacobson-2F-4510R#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Jacobson-2F-4510R(config)#int gi3/18
Config mode locked out until standby initializes
configuration mode locked.'Please try later.'
______________________________________________________________________________
It does it when I input any command once I've gone in to configure the terminal. Any suggestions on how I can solve this?
Other information that may be helpful:
Jacobson-2F-4510R#sh redundancy states
         my state = 13 -ACTIVE
       peer state =  1 -DISABLED
             Mode = Duplex
             Unit = Primary
          Unit ID = 6
  Redundancy Mode (Operational) = Stateful Switchover
   Redundancy Mode (Configured) = Stateful Switchover
               Redundancy State = Stateful Switchover
                      Manual Swact = disabled (the peer unit is still initializing)
   Communications = Up
     client count = 63
   client_notification_TMR = 240000 milliseconds
            keep_alive TMR = 9000 milliseconds
          keep_alive count = 0
      keep_alive threshold = 18
             RF debug mask = 0
Mod  Redundancy role     Operating mode      Redundancy status
5   Standby Supervisor  SSO                 Disabled
6   Active Supervisor   SSO                 Active
InayathUlla Sharieff
Joshua,
In reviewing this, I see that your standby sup in slot 5 is not
completely up.  It shows as disabled in the redundancy state
Please make a console connection to the standby sup in mod 1 and observe
what the current state of this mod is.  Please make sure and log all
console output.  Then you will need to reseat this card.  When you have
done this please attach the output to the SR as well as a current 'sh
tech'.
If possible reseat the module and check the status. It may be that thi sup might be faulty or not able to intereact between the swtich backplane due to some issue which we are nt sure as of now as we dont have complete logs.
Inayath
*Plz rate if this info is helpfull.
