1570
Beginner
Config PPPoE in Router 2811
Hi forum,
I get stuck in one case. One of my customer has two FTTH lines. I have to config PPPoE in routers. In one line I config succesfully, but one line never up.
I call to ISP they ask me to config extactly VLAN id 10 in the physical subinterface. But in subinterface there is no command "pppoe-client dial-pool-number". I check the old modem FTTH, they also config VLAN 10 in Wan interface. I tell ISP why we have the same two FTTHs, but two differrent config ways. ISP says because the two line run in two different infrastructure, two different devices. I don't know how to do now? Can anyone tell me what going on here? The problem stay in customer side or ISP side.
Here is my PPPoE config:
interface FastEthernet0/0
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 10
interface FastEthernet0/1
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface ATM0/1/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 10
ppp authentication pap chap callin
ppp chap hostname xxxxx
ppp chap password 0 xxxxx
ppp pap sent-username xxxxx password 0 xxxx
ppp ipcp dns accept
ppp ipcp route default
ppp ipcp address accept
Thank to any replies
5 REPLIES 5
Beginner
Thanks you, Paolo Bevilacqua,
I has upgraded IOS and see the command pppoe-client in sub-interface.
I cannot vote you now, because the history post disappeared???
Hall of Fame Master
Re: Config PPPoE in Router 2811
I have deletet my postings due to the unfair rating received.
Beginner
I don't understand.
At that time I just rate the post you reply right after my second post. I wait to test upgrading IOS then will say thanks to you and mark the question as answered.
Anyway sorry to not make you happy.
Actually I should believe in you at the first reply.
Hall of Fame Master
If you are not ready to leave full rating for postings that are 100% correct and made with the will to help, please do not leave any rating at all.
Beginner
check to bridge mode configuration on the device.
Content for Community-Ad
July's Community Spotlight Awards
