09-10-2009
07:59 AM
- last edited on
03-25-2019
03:26 PM
by
ciscomoderator
what basic command do i type
1. i want to trak all mac address learnt from port r0/2 on a switch.
2.nms server is 192.168.1.1/24
3.ip add = 2.2.2.2/8
09-11-2009 03:14 AM
Hello Kennie,
you should provide more details:
are you looking for IOS commands or for commands to be given on NMS server to perform an SNMP walk?
in first case
1) sh mac-address-table int typex/y
2) snmp-server community
3) what is the switch management ip address?
Hope to help
Giuseppe
09-11-2009 06:55 AM
i want ios command on the switch to achieve this, the management ip of the switch can be 2.2.2.2/8 ...also.
2. What command will i use to configure a switch so that if password recovery is perform, automatically, the start-up config is delated.
09-12-2009 05:38 PM
interface vlan 1
ip add 2.2.2.2 255.0.0.0
no shut
Password recover of a switch is very simple. Hold down the "mode" button, apply power and, depending on the model, wait for either 10 seconds or port 1 changes color. Go to rommon, enter flash_init, boot_helper and delete "config.text" file. Viola!
