Join Customer Connection to register!
239
robert.jubb
Beginner
Configuration of Microsoft NLB on 6500
                   Static ARP and MAC entries have been put into the core to support the clusters VIP and MAC addresses, additional static MAC should be added as the cluster is split across both cores so the static MACs need to be put onto the inter-core links.
Part of the configuration guide to support Microsoft NLB it is very specific that snooping must be disabled on 6500 interfaces.
This command looks to be unavailable on the core switches. Not sure if this is a code issue.
The IOS Release is 12.2(33)SXH
s72033-ipservicesk9_wan-mz.122-33.SXH4.bin
can any one advice the if the above ios aove supports snooping disablemnt and how go about implement it
0 REPLIES 0
