Configuration Problems Cisco 800er - HTTPS not avaible.
toxicsonline
Hello everybody,
I have a configuration problem with a cisco 800 series router. The client with the ip 192.168.99.100 can access the internte via http but not via https.I wonder why, since there is no exclusion of https in my opinion.
Can someone provide a solution for this issue?
In following the "running config"
I did following replacings in the attached running config file:
EXTERNALHOST1= IP of an external system
EXTERNALHOST2= IP of an external system
xxx.yyy. = anonymized IPs
Thanks for your help,
Marco
htarra
Level 4
Level 4
You have to do something more. After configuring keepalive for load balancing https content, we are finding our web servers are swamped with the error generated from the arrowpoint keepalive. To confirm this, pls try this command sh script ap-kal-ssl
