12-01-2023 05:06 PM
Hi All,
Noob question:
I have network scenario as represented below, and want to configure access to and from the web server in the dmz (http only). I am confused as to how I do this, I am sure NAT should be done at the Edge Router but since its "outside" interface is a private address, and the network to the ISP Router has only two available IP addresses which are configured for each of the two interfaces. How do I configure the Edge Router to route http packets to the ASA and for it to route them to the web server and back out to the ISP? Thank you!
Thank you
12-01-2023 05:21 PM
object network webserver-external-ip
host routerToasa subnet ip
object network webserver-dmz
host x.x.x.x
nat (dmz,outside) static webserver-external-ip service tcp www www
Then in router
Ip nat inside source static tcp <routerToasa subnet ip> <eq www> <isp interface ip> <eq www>
That what you need
MHM
12-02-2023 02:35 AM - edited 12-02-2023 02:36 AM
Hi MHM,
Thanks for the response, I just wanted to clarify:
Is the above an ip address of the Edge Router interface to ASA, ASA interface to Edge Router or is it a Subnet address like 192.168.70.0
And same question with: ip nat inside source static tcp routerToASA subnet ip ------> is this ip address or subnet address?
Sorry for my confusion and thanks for the response.
12-02-2023 03:15 AM
Sorry If I am not clear
I meaning one ip form subnet connect asa to router.
And also same
Ip from subnet connect router to isp
MHM
12-02-2023 04:40 AM
Could you tell me how I test this connection, from say the ISP router? I have setup a simple http server in the dmz, as I cannot use the internal IP address, how do I connect and test the connectivity?
12-02-2023 04:52 AM
From ISP connect use
Http edge router IP (this IP i think public ip)
Ip will NATing to asa outside IP (private ip)
Then traffic will NATing again in asa to web ip (private IP).
12-02-2023 03:27 AM
OK - I will try with the IP addresses and report back - thanks for the quick responses.
12-02-2023 07:38 AM
Hi MHM,
I have configured my Network in this way:
ISP int e0/1 -----> 90.241.179.6
Edge Router int e0/0 -----> 90.241.179.5
Edge Router Outside int e0/1 -----> 192.168.70.2
ASA Router Outside int e0/1 -----> 192.168.70.1
DMZ Web Server Address -----> 192.168.60.2
And I have used your suggestions like this:
ON ASA
object network wbs-ext-add
host 90.241.179.5
object network dmz-server
host 192.168.60.2
nat (dmz,outside) static wbs-ext-add service tcp www www
ON EDGE Router
ip nat inside source static tcp 192.168.70.2 www 90.241.179.5 www
But for some reason this isn't working - any help appreciated.
Sorry for the headache!
12-02-2023 07:57 AM
You need to add ip nat inside and ip nat outside to edge router
You need to add acl allow traffic to web server in dmz
MHM
