11-08-2018 07:57 AM
I have RTR1 connected to RTR2 over a GRE Tunnel. The two RTRs are geographically separated. I would like all traffic from RTR1 to go to RTR2 and ignore the routes between RTR1 and RTR2. Is this possible over a GRE Tunnel or should I be using a VPN between RTR1 and RTR2 vise a GRE Tunnel?
11-08-2018 09:55 AM
You can do it by OSPF, after that the GRE tunnel is up and running.
You can use the default information originate on RTR2 so all traffic from RTR1 will be tunnel towards RTR2.
Something like these:
R2
interface Tunnel0
ip address 172.18.2.1 255.255.255.0
tunnel source Loopback0
tunnel destination 3.3.3.3
router ospf 10
network 172.18.2.0 0.0.0.255 area 0
default-information originate
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip route 3.3.3.3 255.255.255.255 <next hop interface>
R1
interface Tunnel0
ip address 172.18.2.2 255.255.255.0
tunnel destination 2.2.2.2
router ospf 10
interface Loopback0
ip address 3.3.3.3 255.255.255.255
ip route 2.2.2.2 255.255.255.255 <next hop interface>
11-08-2018 11:56 AM
You can go with GRE tunnel and PBR. It is easy to understand and no need for some extra cost of Dynamic routing. It will also help you to maintain a failover case:
PRT1 Configuration:
interface Tunnel1
ip address 172.16.16.2 255.255.255.0
tunnel source FastEthernet0/0
tunnel destination 192.168.1.1
interface FastEthernet0/0
Description WAN Interface
ip address 1.10.9.2 255.255.255.0
duplex full
interface FastEthernet1/0
Description LAN Interface
ip address 10.10.10.1 255.255.255.0
ip policy route-map PBR
ip route 0.0.0.0 0.0.0.0 1.10.9.1
ip access-list extended PBR
permit ip 10.10.10.0 0.0.0.255 any
ip sla 1
icmp-echo 172.16.16.1 source-ip 10.10.10.1
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
route-map PBR permit 10
match ip address PBR
set ip next-hop verify-availability 172.16.16.1 1 track 1
RTR2 Configuration:
ip address 10.10.11.1 255.255.255.0
description LAN Connection
IP NAT Inside
interface Tunnel1
ip address 172.16.16.1 255.255.255.0
ip nat inside
tunnel destination 1.10.9.2
description WAN Connection
ip nat outside
ip nat inside source list NAT interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.2
ip route 10.10.10.0 255.255.255.0 172.16.16.2
ip access-list extended NAT
deny ip 10.10.10.0 0.0.0.255 10.10.11.0 0.0.0.255
deny ip 10.10.11.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip 10.10.11.0 0.0.0.255 any
Deepak Kumar
11-08-2018 04:37 PM
actually, a VPN is recommended, the config is very simple. You are using the public Internet, so just a GRE tunnel is vulnerable. Here is an example of an SVTI:
R1
interface GigabitEthernet0/0
description Link to ISP
ip address 1.1.1.1 255.255.255.0
interface Loopback1
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key cisco123 address 1.1.1.2
crypto ipsec transform-set TS esp-3des esp-sha-hmac
crypto ipsec profile IPSEC_PROFILE
set transform-set TS
interface Tunnel0
ip address 172.16.0.1 255.255.255.0
tunnel source 1.1.1.1
tunnel destination 1.1.1.2
tunnel mode ipsec ipv4
tunnel protection ipsec profile IPSEC_PROFILE
router eigrp 1
network 172.16.0.0
network 192.168.1.0
R2
ip address 1.1.1.2 255.255.255.0
interface Loopback1
ip address 192.168.2.2 255.255.255.0
encr 3des
group 2
crypto isakmp key cisco123 address 1.1.1.1
interface Tunnel0
ip address 172.16.0.2 255.255.255.0
tunnel source 1.1.1.2
tunnel destination 1.1.1.1
router eigrp 1
network 172.16.0.0
network 192.168.2.0
11-09-2018 07:14 AM
As I am getting his point that he " I would like all traffic from RTR1 to go to RTR2" means as a full tunnel so is it correct? and will get the same with EIGRP?
Why am I asking this question becuase he would need a default route on his PRT1 to get connected with his ISP and GRE tunnel so eigp will not replace to default route do to AD value? Here, if we will convert default to floating default route than GRE will go down.
Is there any solution without PBR? Yes, he can configure a static route instead of default route but it is not recommended in case of tunnel fail.
11-09-2018 08:42 AM
There have been some interesting and useful responses and I would like to address a few points. The suggestion of configuring the GRE tunnel and running OSPF over the tunnel is nice and would certainly work and achieve the goal of the original poster. But the response suggesting keeping the solution simple and suggesting that OSPF might be overkill has some validity. But if we want to really keep it simple then there is no need for Policy Based Routing. If you simply configure the GRE tunnel, configure a static route for the tunnel destination using the provider address as the next hop, and configure a static default route using the tunnel peer address as the next hop should be all that is required.
One factor to consider in this discussion is whether to use a dynamic routing protocol or to use static routing. To provide good advice we need more information about the environment. Dynamic routing is appropriate for environments that need to react to changes in the routing environment and to be able to select alternate paths if the primary path has problems. When there are not alternate paths then dynamic routing has no advantage and static routing is adequate. So which kind of environment is this?
There is also a question about using GRE (without encryption) or using vpn. To provide good advice we need more information about the environment and the requirements. As mentioned in one of the responses sending IP traffic over a simpleGRE tunnel does not provide any protection for the traffic. If the traffic between sites contains sensitive information that needs protection then certainly vpn is the better choice. But if there is not much concern about protecting the content then a simple GRE tunnel is easier and involves less overhead and would seem to achieve the goal stated in the original post.
Rick
11-09-2018 09:28 AM
Thanks for your response and here, My question is still open "Yes, he can configure a static route instead of default route but it is not recommended in case of tunnel fail".
As per my interest in the design, I will keep internet failover. If my tunnel went down then (at least) the internet must work. What do you think on this point?
Deepak Kumar
11-09-2018 11:42 AM
Deepak
from your perspective failover and redundancy are important. And most of the customers I have dealt with feel the same. One of the things I have learned is that it is important to understand what the customer wants and to provide that. One of the things I was saying in my response is that we need to understand the original poster and what is their requirements. If they need failover and redundancy then our suggested solution goes in one way. If they don’t need that then the simplicity and low overhead of static routing is appealing. So we need more information from the original poster about what they need.
Rick
11-09-2018 08:58 PM
I want to thanks everyone for helping me out on this. So for some clarification, I do not require any redundancy, I have another solution in place for that. This solution does not require security, this is a low priority. If it helps I can provide an example of the current interface configs and ospf and networking statements in the RTRs ina few days when I return back to the lab. I do not have remote access to these devices from home.
11-10-2018 04:54 AM - edited 11-10-2018 08:56 PM
PRT1 router configuration:
interface Tunnel1
tunnel destination <PRT2-Router-WAN-IP>
duplex full
router eigrp 1
network 10.10.10.0 0.0.0.255
network 172.16.16.0 0.0.0.255
passive-interface FastEthernet1/0
ip route <PRT2-router-WAN IP> 255.255.255.255 FastEthernet0/0
PRT2 Router configuration:
interface Tunnel1
ip nat inside
ip nat outside
duplex full
ip nat inside
duplex full
router eigrp 1
network 10.10.11.0 0.0.0.255
redistribute static metric 100000 1000 255 1 1500
!ip access-list extended NAT
Please note that there is no Security over the GRE tunnel.
@Richard Burts thanks for find mistake.
Deepak Kumar
11-10-2018 01:30 PM
It is good to have clarification from the original poster that their requirements do not include security for traffic between sites. So there is no justification for vpn or encryption of traffic between sites. There is also clarification that they do not require redundancy. I take that to mean that they do not require a dynamic routing protocol running between sites. The config suggestion from Deepak runs EIGRP on the local subnet and on the tunnel. The original poster can decide whether they want the dynamic routing protocol as part of the solution.
I note from the EIGRP network statements and the ACL for NAT that the intention was to have the LAN subnets be 10.10.10.0 and 10.10.11.0. But the configuration of both LAN interfaces uses 10.10.10.0. I assume that this was a typo.
I believe that we are getting very close to a configuration that the original poster can use.
Rick
11-11-2018 02:02 PM
Deepak
You are quite welcome. This kind of mistake is very easy to make (I know this because I have done it several times myself and had it pointed out). One of the advantages of communities like this is that we have multiple people reading the discussion and multiple sets of eyes reading the content makes it possible to find things that we missed when we were writing the response.
Rick
