We are trying to configure a Cisco ME-3400 Switch (with IP Routing IOS) to connect to an AT&T 50Mbps Metro Ethernet Circuit. Below is some IP address data to assist.
Assigned Class C Block:
12.150.225.0/24
WAN IP Address:
12.240.24.90
We just need Internet Connection. We are using a Juniper NS-500 behind the switch for rate (bandwidth) limiting and QoS. The hand-off from AT&T is a 100M Ethernet. So, we can use FA0/1 for the AT&T side and Gi0/1 for the connection to the Juniper NS-500. All other ports will be unused.
Thanks for your help,
Shawn
