Configuring 2504 Controller and 2602E APs
Where do I find complete information on how to configure a WAN with a 2504 controller and Aironet 2602E Access Points.
Thanks in advance
jawad-mukhtar
Level 4
Level 4
I will tel u in short.
Terminate one of interface form WLC to your switch. Your Switche x/x Interface should be in Trunk and Native vlan Allowed.
When u will start WLC
it will ask u to configure management interface give ip to it
Servcie Management Interface give ip to it Must be of same subnet as of management.
Cofigure virutal interface as 1.1.1.1 IP.
after that u will be able to access WLC over Web.
Access it
Crate SSID and define authentication mechanism.
Lastly
Connected Access Point to Switch
Connect Console to AP give it ip address
lwapp ap ip address x.x.x.x
lwapp ap getway x.x.x.x
lwapp controller ip address x.x.x.x
After that app will fine controller and it will appear in wlc
i have given u example if u do some research everthing is availabe on Cisco Site u it will be better.
*** Do rate Helpful Posts ***
Jawad
Jawad
On the 2602i AP.
Configuring it for the 1st time (out from the box). I can access the CLI via console but I don't know the commands to enable accessing the AP via http because all the configuration guides im seeing here use the web configs.
Please assist.
paolo bevilacqua
Wrong forum, post in "Wireless". You can move your posting with the Actions panel on the right.
