Configuring 3750
soofiahtesham
Hello everyone,
This is an easy one for you guys , so I have this spare swicth sitting and I want to configure it to the exactly to one I have right now.
Please tell me which should be the easiest and quickest way to do so ?
For your convience I am attaching the config for the existing swicth.Also the configured swicth is a stack
Thanks for all the help in advance
Soofi
Jon Marshall
Soofi
I suspect you are asking something else but if you simply want to replace the live switch with this one ie. configure this new switch exactly as the one live then just use cut and paste at the console on the spare switch.
Jon
