Configuring Net-Flow
r123
Hi, Guys In the following topology the clients are communicating together using a GRE tunnel and using VPN over IPsec. (GRE tunnel over IPsec). Now I am trying to monitor the WAN traffic of the backbone router of Site 1. I am currently using ManageEngine (Netflow) to monitor the traffic. Netflow has to be configured on the backbone router and traffic has to be sent from the internal network of site 2 to the internal network site 1. Note that cloud 1 is connected to a virtual machine which contains the ManageEngine (NetFlow). I tried to connect the cloud to Site_1 (router) but manager engine could not find the sensors. Kindly find attached all the configurations which were used in this topology. Thanks for your help Regards
balaji.bandi
Just referring to your configuration, i did not see netflow configuration and you are exporting data.
Simple example document for your reference :
https://download.manageengine.com/products/netflow/manageengine_netflowanalyzer_5-min.pdf
BB
BB
