Configuring QOS
peter.saldanha
I have configured QOS in Cisco 1841 router. I want to prioritisation of traffic such as voice and other data traffic such as vpn, citrix, mail, web etc. I will send you my router configuration below. I want to establish QOS so that each traffic should get allocated bandwidth during peak but suppose one of the traffic is not utilised particular time, that bandwidth should be automatically allocated to other traffic. Also Voice traffic should be given high priority. I have 2 serial interfaces with 2MB each. I have bundled the lines so that I will get 4MB, Multilink.
My router configuration is as follows.
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
username cisco privilege 15 secret xxxx
clock timezone Muscat 4
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip domain name yourdomain.com
no ftp-server write-enable
class-map match-all EF
match access-group 100
class-map match-all mail
match access-group 103
class-map match-all citrix
match access-group 101
class-map match-all best-effort
match access-group 107
class-map match-all other-traffic
class-map match-all vpn
match access-group 105
class-map match-all web
match access-group 106
class-map match-all voice
match ip dscp ef
policy-map VOIP
class voice
priority 1000
class citrix
bandwidth percent 20
class web
random-detect
class vpn
bandwidth percent 10
random-detect
class mail
class other-traffic
interface Multilink2
ip address 192.169.1.1 255.255.255.0
service-policy output VOIP
ppp multilink
ppp multilink group 2
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 192.168.125.1 255.255.255.0
ip nbar protocol-discovery
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
bandwidth 2000000
encapsulation ppp
pulse-time 1
ppp multilink
interface Serial0/0/1
bandwidth 2000000
no ip address
encapsulation ppp
pulse-time 1
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 192.169.1.2
ip http server
ip http authentication local
access-list 100 permit udp any any range 16384 32000
access-list 100 permit tcp any any eq 1720
access-list 101 permit tcp any any eq 1494
access-list 101 permit tcp any any eq 3389
access-list 103 permit tcp any any eq smtp
access-list 105 permit ip 0.0.0.0 255.255.255.0 0.0.0.0 255.255.254.0
access-list 105 permit ip 192.168.125.0 0.0.0.255 10.44.10.0 0.0.0.255
access-list 106 permit tcp any any eq www
access-list 107 permit ip any any
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
_____________________________________________________
thisisshanky
Level 11
Level 11
Peter, QOS policies kick in only when there is congestion. When a particular traffic is not passing through the interface, all bandwidth is available to the rest of the traffic passing through, until congestion happens and the respective traffic (that you have classified) will be guaranteed the configured bandwidth.
Also try not to exceed alloacating more than 75 percent of the available bandwidth to traffic, as router generated traffic such as routing protocol updates will not have sufficient bandwidth to pass.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Is my configuration is correct?. I have maximum 32 voice sessions going out, so I have given a priority of 1000. I have given for the rest of the traffic QOS based on bandwidth, is it correct?.
Will the bandwidth be available if not used by any service?
Please see my interface status for your info
Serial0/0/0 is up, line protocol is up
Hardware is GT96K Serial
Internet address is 192.169.1.1/24
MTU 1500 bytes, BW 2000000 Kbit, DLY 20000 usec,
Encapsulation PPP, LCP Open, multilink Open
Link is a member of Multilink bundle Multilink2, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 1 seconds on reset
Last input 00:00:00, output 00:00:25, output hang never
Last clearing of "show interface" counters 3d08h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 44
Queueing strategy: weighted fair [suspended, using FIFO]
FIFO output queue 0/40, 44 drops
6891575 packets input, 35859250 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
497 input errors, 497 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
2908523 packets output, 275856172 bytes, 0 underruns
0 output errors, 0 collisions, 8 interface resets
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Serial0/0/1 is up, line protocol is up
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1
FIFO output queue 0/40, 1 drops
6965017 packets input, 127991617 bytes, 0 no buffer
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
2953866 packets output, 279301215 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
Multilink2 is up, line protocol is up
Hardware is multilink group interface
MTU 1500 bytes, BW 4000000 Kbit, DLY 100000 usec,
Open: CDPCP, IPCP, loopback not set
DTR is pulsed for 2 seconds on reset
Last input 00:00:01, output never, output hang never
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/2/256 (active/max active/max total)
Reserved Conversations 11/11 (allocated/max allocated)
Available Bandwidth 199000 kilobits/sec
7577445 packets input, 68301426 bytes, 0 no buffer
5085380 packets output, 508372838 bytes, 0 underruns
