conflicting route
Sergei Uralov
Hi. Have a problem with cisco ASR1002 IOS XE Version: 03.08.01.S.
Have a bgp instance, and bestpath to destination 195.239.213.1 from 217.150.54.30, but "ip route" output shows me a different way. I can not understand, why?
asr#sh ip bgp 195.239.213.1  bestpath
BGP routing table entry for 195.239.0.0/16, version 273643622
BGP Bestpath: deterministic-med
Paths: (4 available, best #3, table default)
  Not advertised to any peer
  Refresh Epoch 1
  20485 3216, (received & used)
    217.150.54.30 from 217.150.54.30 (10.77.0.46)
      Origin IGP, localpref 100, valid, external, best
      Community: 20485:40399
      rx pathid: 0, tx pathid: 0x0
asr#sh ip bgp 195.239.213.1 255.255.255.0
% Network not in table
asr#sh ip route 195.239.213.1
Routing entry for 195.239.213.0/24
  Known via "bgp 11111", distance 180, metric 0
  Tag 47328, type external
  Last update from 193.106.112.91 2w1d ago
  Routing Descriptor Blocks:
  * 193.106.112.91, from 193.106.112.1, 2w1d ago
      Route metric is 0, traffic share count is 1
      AS Hops 4
      Route tag 47328
      MPLS label: none
In other words, the route 195.239.213.0/24 is not in the bgp table, but is still on the "ip route" table
Somnath Sen
Can you share the output of sh ip bgp 195.239.213.1 without mentioning the subnet musk?
It seems your bestpath is showing route for 195.239.0.0/16 and the AS numbers are also not matching for Routing entry for 195.239.213.0/24
Hi, thx for replay. I have a Ticket for this subnet, and i enters the command clear ip route 195.239.213.1 255.255.255.0 without waiting for reply. And now i have this:
asr#sh ip bgp 195.239.213.1 (Output the same as was)
Paths: (5 available, best #4, table default)
  Refresh Epoch 1
  31133 3216, (received & used)
    78.25.66.237 from 78.25.66.237 (10.63.0.99)
  Refresh Epoch 1
  20764 3216, (received & used)
    193.106.112.103 from 193.106.112.1 (193.106.112.1)
      Origin IGP, metric 0, localpref 100, valid, external
      Community: 3216:2001 3216:4100 20764:3006 20764:3011 20764:3021 20764:3026 50384:1010 50384:2050 50384:3016 50384:4001
  Refresh Epoch 1
    193.106.112.103 from 193.106.112.2 (193.106.112.2)
  Refresh Epoch 1
  Refresh Epoch 1
  9002 3216, (received & used)
    87.245.229.97 from 87.245.229.97 (87.245.225.2)
      Community: 9002:9002 9002:64667
asr#sh ip route 195.239.213.1 (but this output changes:)
Routing entry for 195.239.0.0/16, supernet
  Tag 20485, type external
  Last update from 217.150.54.30 1w0d ago
  * 217.150.54.30, from 217.150.54.30, 1w0d ago
      AS Hops 2
      Route tag 20485
      MPLS label: none
Interesting, but much routes have dead gw (193.106.112.91). It does anonce nothing. But routes are still in sh ip route table
asr# sh ip route | i 193.106.112.91
B        31.207.128.0/18 [180/0] via 193.106.112.91, 2w2d
B        31.207.192.0/18 [180/0] via 193.106.112.91, 2w2d
B        42.96.192.0/19 [180/0] via 193.106.112.91, 2w2d
<CUT>
asr#sh ip bgp 31.207.128.0/18
asr#sh ip bgp 31.207.192.0/18
asr#sh ip route 31.207.192.0
Routing entry for 31.207.192.0/18
  Last update from 193.106.112.91 2w3d ago
  * 193.106.112.91, from 193.106.112.1, 2w3d ago
      AS Hops 4
      Route tag 47328
      MPLS label: none
Seems like asr think that route have a greater netmask, and does not delete route from "ip route" table, even if neighbor doesn't announce network anymore. I plan to downgrade ios. Because this behavior, in my opinion, is not normal.
