10-22-2024 07:35 AM
Is it better to connect a customer to an A9K-4X100GE-SE or A9K-4X100GE port? The -SE means service edge, so better to connect the customer to the -SE card?
The -SE card will have more features available, better QOS, etc?
This is because the -SE card has more memory? more cpu?
The optics used are different on each card? CPAKs on the -SE and QSFP on the non-SE.
Why do they use different optics?
thanks
10-22-2024 12:18 PM
Its all depends on the requirement and presentation you looking to deliver - you can ask local sale partner for the requirement he can suggest to you.
still you looking to know more below guide help you. :
10-24-2024 02:01 PM - edited 10-24-2024 02:23 PM
I have a router with free A9K-4X100GE-SE or A9K-4X100GE ports. The -SE card uses CPAKS, the non-SE card uses QSFP optics. I have optics available for either card.
All else being equal, are there benefits to connecting a customer to an -SE card? Memory? CPU? Features? One or the other card supported for longer than the other?
thanks,
Andy
10-24-2024 11:58 PM
May be i am sure there is a reason for that technically (i am not sure) - worth check cisco partner when you buying and they may have better explanation.
