Connect Fiber Optic Device to CISCO 2911
z0mmer3131
Hello colleagues,
I cannot connect  fiber optic network device ADVA FSP 150 CC to Cisco 2911. I connected the device directly to computer and it worked well but I couldn't make it through the router. IP and DNS are static. To connect devices I use RJ-45 rollover cable.
Here is the info:
Bandwidth: 10Mb
IP Block: 24.43.28.248 /30
Subnet: 255.255.255.252
Gateway: 24.43.28.249
Usable IP range: 24.43.28.250
DNS1: 209.18.47.61
DNS2: 209.18.47.62
Speed: 100
Duplex: Full
Could you please  tell me what is the possible problem is,
Here is Show run listing
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool ccp-pool
 import all
 network 10.10.10.0 255.255.255.248
 default-router 10.10.10.1
 lease 0 2
ip dhcp pool DHCP_POOL
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 192.168.2.1
 domain-name OmniaLocal1
ip domain lookup
ip domain name yourdomain.com
ip name-server 209.18.47.61
ip name-server 209.18.47.62
no ipv6 cef
interface Embedded-Service-Engine0/0
 no ip address
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 24.43.28.250 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 duplex full
 speed 100
interface GigabitEthernet0/2
 no ip address
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/2.1
 encapsulation dot1Q 1 native
 ip nat inside
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/1 overload
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
Hitesh Vinzoda
Level 4
Level 4
Hi there,
Please try using straight over cable or set the cisco side interface as below
Speed=auto
duplex=auto
Hitesh
