Connecticity from one branch office to other with 2 internet leased line
shanilkumar2003
I want to make out connectivity from one branch to another with failover. i have 2 internet leased line connections on both end with public IP provided by ISP. appreciate if you could suggest best approach for connectivity with failover
Thanks in Advance..
Shanil
you can setup a dmvpn network. you can configure redundancy (rounting, failover, meshed if whanted), security etc. in int.
Scales well to more sites.
You have to setup only the hubs (one time) and the spokes are all linked to the hubs, and can tunnels to each other when they need.
http://www.cisco.com/go/dmvpn
Patrick
9 Replies 9
rais
Level 7
Level 7
You can have BGP between the two sites on both links using GRE over IPSec.
HTH.
I can also run ospf bw the tunnels right?
If you set up GRE tunnels between the sites then you certainly can run OSPF over the tunnels.
Rick
Rick
Patrick
Thank you Patrick it is very help full
Hi  All,
If we connect the brnach office using DMVPN , do we need to have Firewall in all the branches or we can route all the branch office traffic to use Head office Firewall.
you need to configure an access list on the routers to secure them.
But the rest is dependend from your policy, if you which you can route anything over the HeadOffice.
Patrick
Thanks Patric
Thanks Rick and Patrick...
Shanil
