02-07-2012 12:20 PM - edited 03-04-2019 03:10 PM
I am trying to research what Cisco equipment can handle 10 1 gig ports comming into it.... I have heard that some of the Cisco equipment just simply can not handle this capacity.... Is there anyone out there with some real world experience and willing to suggest some good equipement?
We are preparing to move all internet traffic through these lines as well as many servers off site as possible...
02-07-2012 12:28 PM
Many Cisco products can do that.
Recommend you get in touch with a reputable consultant or certified Cisco partner to help you choose.
02-07-2012 12:37 PM
We are in the process of of talking to our Cisco Partner. However, I never take one persons or one companies solution and go with it... Is there any out there that I should absolutely stay away from? Anyone looked at a 4900 series solution?
02-07-2012 12:55 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It's true some Cisco equipment doesn't have the capacity to drive all ports at wire-speed, but it's often unusual that they need too. If you know what traffic volume you need to support, you can examine the device specs looking at both internal device bandwidth capacity and packet per second forwarding rate to determine whether the device can support your need.
02-07-2012 03:48 PM
What kind of features do you want?
You don't need to go as far as a 4900 series - a 3750X - WS-C3750X-24S-S - will do the job. 160 gigabits per second backplane, 24 SFP ports (fibre of copper), 65.5 MPPS forwarding rate - as long as you don't need to run fancy routing (IP base), that'll do the job - or you could get the WS-C3750X-24S-E for the more enhanced IP Services feature set.
Cheers.
02-08-2012 10:58 PM
Sorry, but can you please elaborate what you are trying to do?
Your description is vague.
