Connecting office to datacenter
active-energy
Hi Together,
we are currently planning to relocate some of our systems from our office into a datacenter. Basically our configuration is the following:
Office:
LAN and WLAN clients which should receive their IPs from the Datacenter DHCP (172.50.0.0 Network)
development servers within the internal network
Local backup
Cisco ASA 5505 will be installed
Datacenter:
Productive servers within the local and dmz network (Exchange, Web, etc.)
2 VLANS one for the DMZ (172.10.0 Network) and one for the internal network (172.50.0.0 Network)
NAT Forwarding of public IPs to DMZ IPs
What we want to do:
All internet traffic is routed within the location
Clients in the office shall be able to reach any server on the network and servers shall be able to reach any client on the network (both office and datacenter)
My question is, can this be done with an ASA 5505 or do we require something else? Further what are your experiences in such a setup and what would be the best setup to make this setup work ?
Thank you very much
Wolf
r.malviya
What i understand with above scenario is
Internal network (172.50.0.0 >>>>>ASA>>>>>>>>DMZ (172.10.0.0)
okey as u mentioned u created 2 vlan ( DMZ & Internal ) on firewall & u want to route traffic in between of them
then as per my understanding u have to check is there any ACL on internal netwrok device if yes then pls allow there
& on ASA u need to allow on acl & as well as u need to check NAT option , becasue its thumb rule in firewall when u wan to communcate in between of any interface (i.e internal to external / DMZ ) u need to allow ACL & do the NAT
for NAT u can also try with NAT Zero config (means No nat ) vice versa
try it ................hope it will work .
Ritesh
