Connecting peer to peer pfsesnse cisco router IPSEC
bronzenetworker
I get this error after setting up a ipsec connection with my router and pfsense firewall
ICU4-ROUTER-01#show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
10.2.128.50 10.2.66.52 MM_NO_STATE 0 ACTIVE (deleted)
IPv6 Crypto ISAKMP SA
10.2.128.50 is the router WAN
10.2.66.52 is the WAN interface of the firewall
The idea is to connect a cloud environment with a office site network.
Shortly after the connection gets deleted, how do i solve this problem.
To setup the configuration i used this guide: https://www.cisco.com/c/en/us/support/docs/routers/1700-series-modular-access-routers/71462-rtr-l2l-ipsec-split.html
9 Replies 9
Mark Elsen
 -  Review these bug reports : https://bst.cloudapps.cisco.com/bugsearch?pf=prdNm&kw=MM_NO_STATE&bt=custV&sb=anfr
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Can you share router config
MHM
You need the complete, show running-config ?
Yes'
And
Debug crypto isakmp
MHM
Sorry  I still wating ?
can you share the config to check it
thanks
MHM
I had nat inside to outside. I turned it off now since, I want the other firewall to do nat for me. But the problem is that my ipsec tunnel that I have established doesnt send network traffic through the tunnel.
Thanks for more detail
Two issue I see
1- you need to exclude encrypt traffic from NAT
Check this link
https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/14132-ios-D.html
2- there is hsrp are you sure the traffic pass correctly through this router' i.e. this router is hsrp active?
Also are Peer is config to deal with two endpoint not one?
MHM
I tried to share the config, for some reason i cant post it in the forum.
No need I take look of config' and I notice two points I list above.
Check it
MHM
