11-27-2016 04:25 AM - edited 03-05-2019 07:33 AM
We have CME version 10.5 in our Main branch with 100 SIP lines from service provider.
We are opening a remote branch at a different location where we want to use the existing SIP lines from main branch to make outgoing calls and we also want 4-digit extension dialing between two offices.
We'll be having 8Mb dedicated internet for branch and we have 20Mb dedicated internet for Main branch.
What is the best and cheap solution to implement it?
Shahzad
11-28-2016 05:43 AM
Site to Site VPN between CME (Voice) is
Deepak Kumar
11-28-2016 05:51 AM
Hi Deepak,
Thank you for your reply.
Sure we'll use site to site vpn but my question is regarding hardware and software requirements in remote site.
Our plan is to get 4 direct lines and terminate them into router's FXO card, but i don't exactly understand this setup.
Shahzad
11-29-2016 05:41 AM
Not sure about the cheapest option, but I would suggest as the simplest and functional solution :
- A router on branch office to act as voice gateway;
- FXO or E1 for PSTN connection (local calls);
- If you need up to 8 extension on remote office, use FXS cards and connected analog phones;
- If you need more than that, use an E1 card and buy a small pabx to connect on it;
- Set a SIP trunk between the two router and Inter-office calls be routed trough the VPN, but won´t much QoS resources on it, no warranty your QoS settings will be preserved on the cloud.
11-30-2016 01:49 AM
Hi Antonio,
Thanks for your suggestion, we will be having around 25 extensions initially.
How do you see if we just install one Internet router and configure a LAN to LAN IPsec tunnel between two offices and use some of SIP lines from our Main branch?
The main concern to this solution will be QoS.
Shahzad
12-01-2016 08:26 AM
Yeah it works also
about QoS not much you can do, passing voice on the internet cloud
This is a kind of setup we will only know the results after deployed
