connection between HQ and 2 remote sites
Saif.S.Mohammed
we have 1 main site (HQ) and 2 remote office on different location , only the HQ have public ip address and the other remote sites is behind PAT
what's the best way to connect these 3 sites together
note : i've tried DMVPN but it give the PATed ip address to the hub :(
can you help me please :]
7 Replies 7
Hello Saif.S.Mohammed,
In order to Hosts located on remote LAN networks can communicate "freely" between each other, indeed, you need an overlay tunneling technology like DMVPN.
With DMVPN you need a single Public/static IP address, as you may already know, only on the HUB side.
All the DMVPN Spokes can still be using dynamic WAN IP addresses, DMVPN van work with Public NATted addresses on the Spokes.
I would suggest to contact your ISP in order to talk about how you can get a Public/static IP address on your HUB site.
PS: Maybe your ISP can forward the correct ports in your HUB's PATed IP address for DMVPN to work.
I hope this helps.
Best Regards.
This should work. You do not need static IP addresses on the hub routers.
On the HQ-Public router
interface Fa0/0
ip address 37.20.20.20 255.255.255.0
duplex auto
speed auto
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key DMVPNPASS address 0.0.0.0
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set strong esp-3des esp-md5-hmac
mode transport
crypto ipsec profile cisco
set security-association lifetime seconds 120
set transform-set strong
interface Tunnel0
description mGRE-DMVPN Tunnel
ip address 10.10.10.1 255.255.255.0
no ip redirects
ip mtu 1410
ip nhrp authentication DMVPNPASS
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp registration no-unique
ip tcp adjust-mss 1360
tunnel source 37.20.20.20
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile cisco
On the hub routers
hash md5
crypto isakmp nat keepalive 5
crypto isakmp profile HQPublic
mode transport
interface Tunnel0
ip address 10.10.10.2 255.255.255.0
no ip redirects
ip mtu 1410
ip nat inside
ip nhrp map 10.10.10.1 37.20.20.20
ip nhrp map multicast 37.20.20.20
ip nhrp holdtime 300
ip nhrp nhs 10.10.10.1
ip virtual-reassembly in
tunnel source Fa2/1
tunnel key 0
I don't think I missed anything.
Mike
Quick question burleyman,
When you mention '37.20.20.20', who is supposed to own that IP address?
The IPSec traffic sourced from the DMVPN Spokes, should be able to hit the HUB's Router.
At quick glance, the DMVPN config template looks good.
Best Regards.
The 37.20.20.20 is the public IP address of the HQ router, al least that is what the drawing says, and he stated the only place that has a public IP address was the HQ site. He did not say that site was DHCP so we should be good.
Mike
That is correct, I missed that.
However, he said his ISP at the HQ site is using a PATted IP address. That makes me think that traffic sourced from somewhere on the Internet, might not be able to hit the correct ports on the HQ's Router. Based on that, DMVPN will not be able to properly establish a communication channel since the encrypted NHRP Control Plane traffic may not be able to hit the Hub.
As mentioned at the beginning of the post:
"note : i've tried DMVPN but it give the PATed ip address to the hub :("
Anyway, if the remote sites can in fact hit the corrects ports on the DMVPN HUB, the suggested configuration should be good as a starting point to establish a DMVPN network.
I hope this helps.
Best Regards.
Yeah, I did not quite understand the wording on the line "note : i've tried DMVPN but it give the PATed ip address to the hub :("
You are correct that there needs to be a static IP at the hub location for this to work.
Mike
Muhammad Shahid
Saif,
I have used the same solution on my LAB and on a live network for one of our customers.
As you mentioned you already have a public IP at your HUB site and NATed IPs on the spoke,if that's the case i don't show any problem.
