Connection disruption
juniorboniface1
I have 2 ISPs on a branch network with 2 tunnels form my WAN router in the office and the branch network. The branch network keep disconnecting at intervals. wNov 27 20:30:06.510: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:06.510: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:30:09.044: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:30:09.044: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:30:10.812: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:10.812: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:30:13.732: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:30:13.732: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:30:15.108: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:15.108: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:30:18.372: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:30:18.372: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:30:19.910: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:19.910: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:30:23.192: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:30:23.192: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:30:24.796: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:24.796: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:30:28.112: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:30:28.112: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:30:29.182: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:29.182: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:30:32.688: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:30:32.688: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:30:34.046: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:34.046: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:30:37.208: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:30:37.208: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:30:38.798: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:38.798: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:30:42.020: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:30:42.020: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:30:43.620: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:43.620: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:30:46.710: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:30:46.710: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:30:47.930: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:47.930: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:30:51.208: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:30:51.208: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:30:52.800: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:52.800: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:30:55.830: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:30:55.830: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:30:57.482: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:30:57.482: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:31:00.548: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:31:00.548: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:31:01.790: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
*Nov 27 20:31:01.790: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Nov 27 20:31:05.218: EIGRP: Sending HELLO on Tu2 - paklen 26
*Nov 27 20:31:05.218: AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Nov 27 20:31:06.160: EIGRP: Received HELLO on Tu2 - paklen 20 nbr 172.28.5.25
hen i checked the branch's router log the below error is what i got.Please help
6 Replies 6
Can i see config
Please see the attached.
It is the config for the branch location with the error
Many thanks
Your config is correct except
Try first Use interface not use ip in tunnel source and monitor the eigrp is stable or not
Try use tunnel key fod both tunnels (you need to add tunnel key in other router).
If above not work
Share
Show ip eigrp neighbor
MHM
Hello ,
Thank you for your feedback.
The above did not work. Could it be a result of the cisco 1000 series switch ?
Also, the sh eigrp ne
Show ip eigrp neighbor detail
I need to see this
From output the hello is send receive between peer since it appear as neighbor' q-count non zero that good meaning the update also send and receive ack for it.
Uptime is small so I think it is issue of ISP not your issue.
MHM
