01-23-2014 04:03 PM - edited 03-04-2019 10:09 PM
what we have:
2 routers 2911
2 switches 2960
2 hp proliant servers one is named TCM, one is named FDM,
1 cisco ASA Firewall device
we have three networks coming in:
one network containing TCM and FDM servers,
one totally different network named siemens,
one totally different network named ESF Area
The .IP Addresses of TCM server:
4 NICs, 3 used, 192.168.0.9/24, 192.168.1.9/24, 192.168.170.77/26
The IP Addresses of FDM Server:
4 NICs, 3 used 192.168.0.11/24, 192.168.1.11/24, 192.168.170.78/26
A totally differenet /26 network is used in siemens with a firewall having IP 192.168.170.125/26 , and a server "X" with IP 192.168.170.11
What we have to do..
ESF area should be able to connect and communicate with FDM and TCM,,physical connectivity coming through ESF is through fiber,,,can terminate them to normal connections using SFP modules on switch.
TCM and FDM and their complete LAN containing other PCs (not present now,,,in future) should have internet access through firewall..
TCM and FDM both should be able to connect and communicate with Server "X",, on the siemens network..
MY requirements:
Please correct or change the IP addresses if wrong, suggest new,, please note that we are as of now using 192.168.170.xyz ip addresses as of now with subnet 255,255,255,192/26.. for communication with siemens..
if we require routers in this scenario,, what will be their work and purpose and configuration to route,,give complete configuration.
what will be the configuration on firewall ASA 5510.
what configuration should be there on the switches and how should they be used.
01-24-2014 12:52 AM
Hello.
Could you please draw a diagram, especially how TCM/FDM currently connects to siemens? And please draw all the IP-addresses are in use by network equipment.
What security requiremement do you have? So far I saw no requirements for restrictions or filtering (except of Internaet access).
What are the expected traffic types between networks?
What is the expected link utilization between networks?
What is the expected Internet link bandwidth?
Draft guess:
I would suggest to use ASA for inter-network filtering and Internet access.
Switches could be used for device interconnectivity and (as you mentioned) for fiber termination.
One router could be used for TCM/FDM (to route traffic between subnets).
One more router could be used for any other purpose (like CE for Internet).
01-24-2014 03:35 AM
Thanks a lot Mikhailovsky for the response.. Please find the diagrams attached.
01-24-2014 12:00 PM
Hello, Mujeeb.
What about all the other questions:
01-24-2014 12:59 PM
Dear Mikhaelovsky,
Thanks for the effort,
•What security requiremement do you have? So far I saw no requirements for restrictions or filtering (except of Internet access).
As of Now we dont have security requirements.
•What are the expected traffic types between networks?
Traffic type is data
•What is the expected link utilization between networks?
n/a,, assumption can be made as this is not in our scope of work
•What is the expected Internet link bandwidth?
5 mbps
•Do you have any routing between TCM and PLC networks (192.168.0.0/24 and 192.168.1.0/24)? If not, then why?
No routing enabled, not required.
As of now our scope is just to initiate the things, the internal it department will beresponsible for the above criteria from there on.
Mujeeb SM
01-25-2014 04:49 AM
Hello, Mujeeb.
If you have no security requirements, then the easiest thing to do is to enable routing on the routers and create L3 interface per subnet.
For first-hop redundancy use HSRP.
This will solve all your interconnectivity issues you could have.You will also be able to decommission redundant NICs on your servers, unless you need them for dedicated L2 domains.
As you free up NICs on the servers, you will be able to build either LACP (to a single switch) or a redundant interface (to a pair of switches).
For Internet access use ASA.
