connectivity issue
vickyg7591
As shown in attached file
pc3 & pc6 are in vlan 10
pc7 & pc5 are in vlan 1
how all pc3,6,7,&10 will communiate with all other pcs that are in other n/ws
switch int f0/1 already configured as trunk port ...
then how configure router port as trunk...please help me
devils_advocate
Level 7
Level 7
You need to look at a 'Router on a Stick configuration' such as the one below:
https://www.freeccnaworkbook.com/workbooks/ccna/configuring-inter-vlan-routing-router-on-a-stick
Already try router on stick but others computers are not pinging
there are two possible problems:
1. See if PC3, 5, 6, 7 can ping each other. If no - your router on a stick does not work
2. For 3, 5, 6, 7 to be able to ping other PCs, you need to have routing between routers.
