Console port connection problem
Lollo89
I'm having problems connecting to the console port of a CISCO ISR4321, both USB and RJ45.
The COM port is recognized by Putty but when opening the terminal I am not allowed to enter any input, I have the classic black screen with the green cursor stopped. I am sure that my console cables work since I have tested them with other CISCO equipment with positive results. On Putty I have also tried changing the speed and other parameters but to no avail, what could the problem be due to?
Lorenzo
8 Replies 8
Leo Laohoo
Console into the router and reboot.
Post the entire boot-up process.
@Lollo89
Get a cable for USB mini-Type B and alternativelly use that Port for testing.
Hi Flavio
I also tested the mini-Type B USB cable but with the same result.
So, probably, the router have some problem.
I think so, too. I also tried another new ISR4321 and had the same problem with both mini USB and RJ45. Instead trying with other CISCO equipment I can get in and manage the configurations.
Those 2 4321 are Brand New devices?
If so, maybe It would be recommend RMA
Only one of the two devices is new
Humm...well, I would suspect the PC, driver cable etc because two devices, one new and the other used, with the same problem, not usuall.
 Unfortunatelly, access different device is not a perfect prove because some device is different. I face issue with cable connecting to Access Points while I could connect to switch just fine.
 Try to console into the 4321, reload it, and share the logs here. Let´s see if something interesting shows up.
