Consult / doubt
a.guillen
Gurus.
Let me know in what case I must be upgrade my router 1841. In this moment I have DRAM 256 / Flash 64 and using IOS 15,x. This only for curiosity, ???
Collin Clark
Fix security vulnerabilites
Bug fixes/crashes
You need a feature that is in newer IOS
You need a feature that is in a different feature set
There are typically three reasons:
  1. the running IOS has a bug that affects you
  2. the IOS has a security-vulnerability that is relevant to you
  3. you wnat to use a feature that is only available in the newer IOS.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
