Core Switch or SDH Equipment
m.salcedo
Hi Expert,
I have a requirement to connect two 3750 switch with 10G speed between two sites with 150km distance. We will lay-out our own fiber (48 core) between two sites. I just want to consult the following:
1. Could i use two core switch 6500 with single mode fiber as a transport equipment?
2. Or i need to use SDH equipment because of the distance concern? If so do i need a repeater?Could i use Cisco Metro Core ONS, which one?
3. Any other option to achieve this requirement?
Thanks in advance.
Mike
Jeff Van Houten
Level 5
Level 5
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/data_sheet_c78-455693.html
Says you're limited to 80km direct switch to switch.
Hello Jef,
Thanks for the reply.
However the required distance is 150km. I did some reserch and i found the solution to my requirement  to reach 150km distance between two 3750 switch is Via ONS or via SDH. See below.
1. Via SDH
3750 switch  >   ASR > SDH > SDH > ASR > 3750 switch
OR
2. Via Dark fiber
3750 switch  > ASR > Cisco ONS > ASR > 3750 switch
My only problem now what model of Cisco ASR, ONS and SDH equipment i will use for this 150km distance requirement.
Could you advise?
Thanks.
Mike
With such an expensive project, do no hesitate to contact the Cisco Sales office. They will help in making the right choices, first and foremost of a certified Cisco partner.
DuncanM2008
As Paolo said get Cisco involved direct, I would add that if you're laying fibre you would be wise to maximise your investment and light either end with DWDM kit so you can ultimately grow In the future.
You could also lease wavelengths depending on what line of business your in ;)
SDH is the way to go.
