Could set disable/enable learning
ken.vance
Dear All,
When saving my config using 'wr mem' I get four lines of text:
And  the config saves without issue.
Does anyone know what this means?
Ken Vance
ehoffman
I know this old but I ran into this today and have an answer for you. You were probably using an 4 port hwic card in an EHWIC slot. Hope this helps someone else down the road.
Giuseppe Larosa
Hello Ken,
in order to get better help provide:
an example of the output
router model and IOS image name (sh ver)
Hope to help
Giuseppe
Hi, thanks for your response:
RC06#show ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(10c), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 23-Jul-07 22:43 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
RC06 uptime is 1 year, 44 weeks, 5 days, 23 hours, 18 minutes
System restarted at 13:19:53 BST Thu Jul 31 2008
System image file is "flash:c2800nm-spservicesk9-mz.124-10c.bin"
And again:
RC06#wr mem
Building configuration...
[OK]
ehoffman
