Routing
Don't miss this Cisco Catalyst 8000 offer
Labels
Finding accurate answers to your questions and issues is always gratifying, but what if these answers are shared globally across different languages? The Cisco Community team has been working on a proof of concept (PoC) to take Accepted Solutions in...
Kelli Glass by Community Manager
  • 10277 Views
  • 7 replies
  • 16 Helpful votes
The host for my current server (Windows Hyper-V machine with four or five VMs) that handles my email and web sites is going away. I'm planning on moving that physical server to my house and using DDNS to route that traffic in. Realize this is very lo...
Hi,We have mGRE DMVPN tunnle between one Hub and 7 Spokes. Other 6 Spokes are working fine but one Spoke is not connecting to Hub.Spoke shows DMVPN on IKE state (tunnle is not working) and Hub is not adding nhrp entry in table.Spoke DMVPN TunnelPleas...
INBKIT_0-1713981579965.png INBKIT_3-1713982713738.png INBKIT_4-1713982931986.png INBKIT_5-1713983001947.png
INBK-IT by Level 1
  • 93 Views
  • 2 replies
Hi, we have a WAN and VSAT connection to one of the site. WAN is primary and VSAT is secondary link.We have dedicated router for WAN and VSAT. VSAT link is connected to one of the LAN access switch.Could you please help me, what kind of configuration...
inhamit by Level 1
  • 222 Views
  • 8 replies
Hi All,I have a couple of C9300 L3 switches that are connecting to an ASA firewall. The NTP and the syslog server for the switches are located behind a firewall.When one of the switches request/send packets the gateway IP is the source address on the...
Ranjita by Level 1
  • 67 Views
  • 2 replies
Can someone tell me how do I do routing here ? it does not matter if it is static or dynamic I just want to ping same vlans and also I dont want to have different vlans to be pinged
Hi Guys, i had this problem for 8 hours now and can't seem to get it cracked... after i input the command copy xmodem: flash:c2960-lanbasek9-mz.152-7.e9.binand using the SecureCRT going to Transfer > send xmodem I get this and after that nothing happ...
Hello,we have deployed pair of 9500-32C in Stacwise-virtual. It is Aggregation node of big site and connecting to backbone by 2 EBGP links (one from each switch).I have noticed long downtime during ISSU and as we are deploying more of these to other ...
ms339r001 by Level 1
  • 85 Views
  • 3 replies
hi guys thanks for your suggestions in advancehere is my lab setup sorry for the primitive drawing(TYPO in CT2 Bib1/0/12 it is actually 123.123.123.242/30)i modified ips to fake ones. 10.0.22.1/24 is one of our vlans that has full internet access.CT1...
gabecz by Level 1
  • 130 Views
  • 2 replies
Hi All,I have 2 networks connected via OSPF. I need to route the connected networks to a third network via BGP.I noticed that BGP peering is established but no entry is visible on the routing table.Below is an extract of BGP config:router bgp 65200.1...
Ranjita by Level 1
  • 240 Views
  • 11 replies
Hi, how are you :). I have one question, about router  Cisco 2911, and Juniper Netscreen 25, ver 5.4. I must start IP Sec tunnel between these two devices. I must use agressive mode, I saw this in configuration document. Question, how can I use agres...
