CPU Profiling - Cisco Router
guruprasadr
Level 7
Level 7
Hello Experts / Cisco Tech Engg,
What is meant by enabling the "CPU Profiling" on Cisco Routers.
What are that Commands involved in doing / enabling the same ?
What are the Advantages & Disvantages of CPU Profiling ?
Thanks in Advance for all your HELPS
Best Regards,
Guru Prasad R
guruprasadr
Level 7
Level 7
Hello Experts,
Can somebody address this Query, your advices / recommendations are awaited.
Thanks in Advance.
Best Regards,
Guru Prasad R
Guru,
Though i don't know much in detail about CPU profiling, i have worked in the past with Cisco TAC wherein they have asked me to configure the same to troubleshoot high CPU utilization
The command necessary are mostly hidden in the Cisco IOS
We first use the following command to get the addresses
show region | incl main:text
Then create a CPU profile
Router(config)#profile 60008AF4 61D5A5C3 4 ...note the values entered depend on platform. sometimes u need to include the 0x in the beginning...
4 at the end is the increment
You can use show command to view the cpu profile
sh profile detail, sh profile terse
U start the profile and then stop it after a while and the output is then submitted to TAC
Router#profile start
Router#sh profile terse
PROF 60008AF4 61D5A5C3 4
PROFSKIP 6000D354
0 0 0 0 0 1 0 0
PROFSKIP 601C2B74
0 0 1481 0 0 0 0 0
...output omitted
Router#profile stop
Router#clear profile
Narayan
HI Narayan,
Your POST was really informative. Recently we are working with Cisco to troubleshoot the High CPU Utilization Problem.
Cisco has recommended to enable CPU Profiling and share the results on TAC. Before all i wanted to know some in details.
Thanks for your POST => Have Rated
Best Regards,
Guru Prasad R
