CRS bundle-eth
coastail
I go to make a LACP layer3 bundle. One of these interfaces config like this:
interface GigabitEthernet0/3/0/2
mtu 3014
ipv4 address X.X.X.X 255.255.255.252
ipv4 verify unicast source reachable-via any
mpls ldp
router ospf 1
area 1
   authentication message-digest
   message-digest-key 1 md5 encrypted ********
------------------------Below is my draft---------------------------------------------------------
bundle id 1
bundle id 1 mode on
duplex full
speed 1000
interface bundle-eth 1
mtu 3014                                                <--- or under int g0/3/0/2  ?
                                                              <--- MTU is still 3014 ?
mpls ldp
interface bundle-eth 1                              <-- or int g0/3/0/2 ?
router ospf 1
area 1
Q1. I don't know it's right or wrong ,and if there is anything I didn't mention ?
Q2. Does there any hardware limit ? (eg.  bundle 0/1/0/0 ,0/2/0/0  port that on different PLIM or SPA)
Giuseppe Larosa
Hello Coastail,
as you would like to configure a L3 LACP bundle also MPLS configuration applies to the bundle
>>Q1) I don't know it's right or wrong ,and if there is anything I didn't mention ?
you need to use mode active with mode on you are not using LACP
mtu has to be set on member links also
see
>> To enable active or passive LACP on the bundle, include the optional mode active or mode passive keywords in the command string.
http://www.cisco.com/en/US/docs/routers/crs/software/crs_r3.9/interfaces/configuration/guide/hc39lbun.html#wp1011822
it is supported also on multishelf configuration
see same link
note:
I would not recommend to use an LACP bundle on a router like this, but I would use two parallel L3 /MPLS links
Hope to help
Giuseppe
Link bundles have been extensively used on CRS-1and in production networks. Link bundling does make sense in many scenarios especially when you are not losing any critical feature that would otherwise work on ECMP links but does not work on link bundles.
