01-08-2018 10:34 AM - edited 03-07-2019 12:22 AM
Hello Guys
CSR1000v , i m not able to add 2nd EIGRP AS number , it took AS 103 but didnt take AS 104
any luck to solve such issue
thanks
01-08-2018 11:09 AM
Hi Ibrahim,
Do you receive an eror message when adding the second Eigrp process?
01-08-2018 01:20 PM
It might help us understand the issue if you would show us how you are attempting to add the second AS number.
Rick
01-09-2018 01:33 AM
Hello Guys
CSR1000V
router eigrp 103
network 192.168.1.0 0.0.0.255
router eigrp 104 --->>>then hangs here , same if i reload the box
thanks for ur help
01-09-2018 04:24 AM - edited 01-09-2018 04:26 AM
I think it should allow you to create other classic instance. Have you tried creating a named EIGRP instance?
router eigrp TEST
address-family ipv4 unicast autonomous-system 104
