CSR1000v WCCP
does anyone have experience with CSR1000V and WCCP ?
We're struggeling with getting the physical WAE connected onto the CSR.
Debugs show the HIA packets but it's not coming up.
We also tried to enable promiscious mode on the interface which also didn't fix the problem.
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.3(2)S2, RELEASE SOFTWARE (fc1)
IOS XE Version: 03.09.02.S
It runs on ESX
Steve Fuller
Level 9
Level 9
Hi Brandon,
On your ESX vSwitch, what security settings do you have? I've not tried the CSR 1000V with WAE/WCCP, but have seen issues when using CSR 1000V with Riverbed Steelhead unless I changed the Promiscuous Mode setting under the vSwitch Security tab from Reject to Accept.
Tried with reject , tried with accept, no working.
packet dump shows HIA packets and conversation between WAE <->CSR
it was the assignment method.
CSR supports only mask assignment like the ASR.
Problem fixed.
