CSS 11500 SMTP server load balancing
r.docuyanan
Anyone can help me in some configuration guide or links or whitepaper on Content Switch server load balancing for SMTP servers, most of the examples are for WebServer.
Had anyone done lb for incoming tcp 25 connections to VIP to rounrobin bet two SMTP servers with client source ip persistence?
arvenugopal
I have SMTP setup with the below basic configuration, This works, however I would like the mail messages after being recieved by the client to be sent to remote servers by their own real ipaddresses, so that the VIP is not a single IP address that may get blacklisted easily. I have about 4 smtp servers. I also need the real client IP addresses to show up in logs.
I have 2x11503's each with 2sfps each uplinking to its own 2960.
Any help?
(ips changed about; requests come in on 192.168.1.230, 10.10.10.x is the mailserver real ip network)
They have the a gateway of 10.10.10.155
configure
!*************************** GLOBAL ***************************
ip route 0.0.0.0 0.0.0.0 192.168.1.238 1
!************************* INTERFACE *************************
interface 1/1
trunk
vlan 25
interface 1/2
trunk
vlan 21
!************************** CIRCUIT **************************
circuit VLAN21
ip address 10.10.10.151 255.255.255.224
ip virtual-router 5 priority 101 preempt
ip redundant-interface 5 10.10.10.155
circuit VLAN25
ip address 192.168.1.228 255.255.255.240
ip virtual-router 1 priority 101 preempt
ip redundant-vip 1 192.168.1.230 shared
!************************** SERVICE **************************
service mail25_1
ip address 10.10.10.131
active
service mail25_2
ip address 10.10.10.132
active
!*************************** OWNER ***************************
owner http_owner
content mail_1
add service mail25_1
add service mail25_2
vip address 192.168.1.230
balance weightedrr
protocol tcp
port 25
active
!*************************** GROUP ***************************
group mail_group
active
Ignore previous, my group was left from another test configuration.... suspending that made it work immediatly.
